Salta al contenuto principale
Machine-readable instructions that direct computer processors.
Is my code wrong on my javascript
My code must be wrong because i keep getting an error that says "Illegally formed XML syntax. (line 5, file "Code")"
Heres my code
<FORM>
<INPUT TYPE="button"
VALUE="click here to add a game"
onClick="parent.location='mailto:1637206@student.ucps.k12.nc.us?su... would like to add a game to the website'">
</FORM>
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi Andrew
So ,i tried yout code, and it did work, but i did see some syntax issues.
In most cases if you make one or two small mistakes in HTML, the browser 'fixes' it for you.
The 'mistakes' i saw are:
1. The button doesnt termintate. For each HTML element, it needs to terminate, ie. open, and close.
There are 2 ways to do this.
<tag id="tag1">somestuff</tag> (open and close )
<tag id="tag2" /> (self closing)
You seem to close the FORM element with a "</FORM>" at the bottom, but you never self closed the "INPUT" element.
2. It might not be the cause, but it should be addressed, is that you dont have any HTML tags either.
All html documents need to start and end with <html>...</html>
And should also contain a header, and body elements.
Here is your code, with my small modifications:
<html>
<head>
</head>
<body>
<FORM>
onClick="parent.location='mailto:1637206@student.ucps.k12.nc.us?su... would like to add a game to the website'" />
</FORM>
</body>
</html>
I hope this helps
Ian
PS, For more info, try using the W3Schools website: http://www.w3schools.com/html/
Punteggio 1
Preparati per le riparazioni future
Aggiungi la tua risposta
Andrew Goodson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 288
