Why is the R2 button interfering with the left analog stick?
When I press the R2 (right trigger) the left analog stick moves (not physically) to the left. It is interfering directly as I saw it using the DS4windows software to analyze the input data.
What might be the problem? Hardware? Software?
Questa è una buona domanda?
8 Commenti
i have never seen this but
it would most likely be hardware as ps3 controllers had issues like this
da Alex Hus
i have this same problem except my left stick goes up, and also when im holding up on left stick the levels bounce from 50-75% basically spamming up.
da dexdhaley
i have this same problem when pressing my right trigger it adds an imput on my left stick to go up even tho the stick isnt moving when i do move the stick it will kinda fight between the inputs this is on a aftermarket xbox one controller that i uses on windows
da David James
I have a problem with my ps4 controller where when I play minecraft if I press r2 it starts drifting looking left and it is annoying I tried a hard reset on the controller, also set settings to default and and done the hold down analog for 30sec trick but it does not work so can I confirm it is a hardware problem and if so what part should I fix
da The Boys
I haven't personally run into this issue, but I could ask some follow-up questions that could help identify the cause.
Were there any recent repairs done just prior to this issue's first appearance? If so, then what?
If this issue just randomly appeared for no reason (and no prior attempts were made) then do you remember any specific circumstances that might somehow be related?
Are there any other strange occurrences with the remote aside from this specific issue -- that you've noticed?
da Robert
Mostra altri 3 commenti
