Salta al contenuto principale
The LG Optimus L90 is a smart phone from the third generation of the "Optimus L" series of phones manufactured by LG Electronics.
12 Domande Visualizza tutte
Why is my Touch Screen not working?
My touch screen does not register finger placements on the screen.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Screen protector Interference
Your screen protector may be the cause of the issue you are having. Remove your phone case and then proceed to use your touch screen. If your phone registers your finger placements, then your screen protector was the cause of your problem.
Screen is Locked
If your screen is stuck on one image and turns unresponsive, it is usually a software issue. Powering the phone on and off is a potential solution. If the phone’s display does not stay on or come on at all, then the lock button could be interfering. Try wiggling around the lock button or taking the back cover off the phone to see if there is anything interfering.
Screen Cracked
If the screen is physically cracked or damaged, then a replacement is usually the only fix here.
Punteggio 1
1 Commento:
i bought a tablet at wal mart
i bought a tablet from wal mart in 3/5/16 and i didnt know it was damage until my daughter came home from her trip on 3/27/16 that when we found it was damage and took it back to wal mart they wouldnt replacement cause the 15 day warrant was up how can i get replacement for it i even have the recipt to
da
Wow! Your tips was certainly great! Thank you so much!
bold text
Punteggio 0
Aggiungi la tua risposta
Julie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 8,343
