Salta al contenuto principale
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
180 Domande Visualizza tutte
SD Card Slot not working properly
As it says in the title. The SD Card slot in my LG G3 is not functioning properly. It will mount and then unmount the card repeatedly and endlessly. Is there any way to fix this or repair the slot?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Have you tried another microSD card? The microSD card slot may be physically damaged or burnt inside if it still doesn't work.
Punteggio 1
4 Commenti:
I've tried 4 different sd cards and they all had the same result. I've also tried cleaning it some with isopropyl alcohol and canned air to no effect. No clue as to how it could have been damaged as it just randomly started doing it the one day.
da
Did you ever get this fixed, OP? I've been having the same issue for months now and I can't ignore it anymore
da
Unfortunately I was never able to get it fixed. I ended up getting a refurbished G4 for 200$.
da
Thanks for the answer! I've resigned myself to a new phone (V20) as well...
da
Aggiungi la tua risposta
mitchellblu3 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,001
