Salta al contenuto principale
Repair information and support for walk-behind lawn mowers made by the Toro Company.
How to replace cord
What size of wrench/socket is needed to remove cover?
Questa è una buona domanda?
Punteggio 2
3 Commenti:
Would you mind giving us the model number?
da
ph-xt675-2011 pull cord wont rewind
da
need 10mm socket to take top off
da
Aggiungi un commento
2 Risposte
Well that depends on the size of engine u have . (I'm sorry if my answer sounds rude kk) Now, hopefully u have ur Sockets still in their boxes that they came in. If u do just use ur common sense and take one socket that u might think will fit. If it doesn't then try another one. And eventually u will find the right one that fits.
Punteggio 0
2 Commenti:
Would that be metric or standard sockets? Would a cresent wrench work? Why does the cover need to be removed? What are they trying to fix? Do they need a guide? Shouldn't you find out what model it is first as Toro has been making engines for over 100 years? Is this a gas or electric engine? Is she looking for a replacement electric cord or a replacement engine start cord for a gasoline operated machine? Should she go here and enter her model number to find the replacement part? https://www.torodealer.com/en-US/Pages/p...
" 'Course that's just my opinion, I could be wrong."
da
No your not wrong. All your questions are Valid ones
da
Parti & Attrezzi Popolari
the cord you pull to start the engine is locked . What do I need to do to free the cord?
Punteggio 0
Aggiungi la tua risposta
mojokatt57 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 676
