Salta al contenuto principale
Lanciata in Giappone il 12 dicembre 2004, in Nord America il 24 marzo 2005 e in Europa il 1 settembre 2005.
Number of problems with my PSP 1000.
Here's the deal: a friend of mine was just going to toss out his PSP, but I convinced him to let me tinker with it, to see if I could fix it.
The battery has difficulty holding a charge.
The nub/joystick is non responsive and has sporadic movements.
The D-pad seems to want to gravitate the curser down and right.
Any suggestions on how I can fix these issues? Or is the system too far gone?
Questa è una buona domanda?
Punteggio 3
1 Commento
why my psp is slow when playing video
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You might be able to solve the D-Pad issue with the PSP Button Guide.
It is a really old hand console, so the battery should be dying by now. Unless you found another battery, it'll need to be cabled to the wall.
Maybe try dusting out the joystick when you go in to clean up the D-pad buttons and see if that works?
Punteggio 6
Parti e strumenti correlati
Acquista tutti
man your psp is awsome its almost like new all you have to do is open your psp and take out the joystick (but remove the round top before opening it) and take out the small black piece thats under the round top
then place it properly back into its place
Punteggio 1
I can do 2 for you
Immagine PSP 1000 Pulsanti
Guida
Sostituzione pulsanti PSP 1000
Difficoltà:
Facile
15 minutes
Immagine PSP 1000 Batteria
Guida
Sostituzione batteria PSP 1000
Difficoltà:
Facile
1 - 3 minutes
Punteggio 0
4 Commenti:
yeah, but you are almost a year to late ;-) and its the same answer.
da
there is no late or early
da
but it's the same answer as above, so you have not given anything new...
da
well 1 thing.the battery
da
Aggiungi la tua risposta
Colin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 8,073
