Salta al contenuto principale
Released September 2014, the LG G3 Vigor is smaller and cheaper than the LG G3.
8 Domande Visualizza tutte
Why won't my phone turn on?
I just tried to turn my G3 Vigor on and nothing happened. What should I do if it won't turn on?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
7 Risposte
Risposta Più Utile
Make sure that the phone is charged. It won't turn on when the battery is uncharged, so you need to plug the phone and charge it and see what would happen.
Punteggio 1
Loose the phone,
Heat the board with solding paste( flux)
Let it get cool and jail the phone back.
Good luck..
Punteggio 1
Hi Jared,
Check out this troubleshooting page for the LG G3 Vigor. If you're still having trouble with your phone, comment back with some more details about your issue ( Age of your phone, what solutions you've already tried, ect. ) and we'll continue to try and help. Good Luck!
Punteggio 0
1. Check the battery
2. Check the battery sensors
3. Make sure the power switch has water or other deposits
4- Activate the device using the material of the frying and heating a light at 350%
Punteggio 0
The reason for the sudden shutdown of the phone during use and battery is charged 100% without any external cause
Punteggio 0
Alexa will not answer
Punteggio 0
  • Make sure the battery is fully charged
  • Check if the charger is working properly
  • Check for the moisture on the phone
  • Boot the Nexus 5/5x in Recovery mode(Worked for me)
  • Go to the authorized repair store to fix the hardware issue
Source : https://fixyourandroid.com/fix/how-to-fi...
Punteggio 0
Aggiungi la tua risposta
Jared Stickl sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 358
