What do I do if my device freezes?
My LG G3 Vigor froze on me while I was using it. It has been frozen now for the past ten minutes, what should I do to fix this?
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Press and hold the "Power" button and see if the device would turn off. Wait a few seconds and then reset the device by turning the power back on.
Remove the case from your phone and remove the battery. Wait a few seconds,put the battery back in and after you do that, turn your phone on.
Well, I had the same situation and always, I have to do the battery removal and soft re-start. This does not explain why just a simple re-start (On/Off cycle) using power switch does not work. During this freeze, only option is to remove the battery and re-insert and then do a soft restart. Any clues.?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 645
