Salta al contenuto principale
Repair and troubleshooting information for the Suzuki FA50 Moped.
Unit does not start
The unit has been sitting for 6 years. I cleaned carb--has great spark and 60psi compression. Put in Fresh Fuel-Has enough oil, Still does not start--any ideas 1986 Suzuki FA50
Update
Not even a hint of starting. However when the spark plug is removed we get a puff of air/compression from cylinder. Very little gas if any on spark plug no matter how many times you kick start it.
Questa è una buona domanda?
Punteggio -1
2 Commenti
what does it do when you try to start it?
da
Do you have a spark?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sounds like you have carb problems, or a reed valve problem. First things first, unplug the fuel line and make sure the petcock is working. Next clean the carb, make sure all channels and passages are clean, finally check the reed valve condition.
Punteggio 1
Parti & Attrezzi Popolari
Aggiungi la tua risposta
Paul Allan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,060
