Salta al contenuto principale
A Windows 8 smartphone equipped with a 1 GHz dual-core processor, LCD touchscreen display, 8GB of storage, and a 5MP camera with 720p HD video recording.
Can't connect to the internet
I am trying to use the internet browser on my Nokia Lumia 521 but the phone doesn't load any webpages.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You should first check to see if the Wi-Fi is on. Select Wi-Fi in the settings list and if it is off, drag the switch to the right and it should turn orange. If the Wi-Fi is already on, you should try moving closer to the source in order to obtain a better signal, and if that connection is still not working, you may be connected to the wrong network. Select Wi-Fi under the settings menu, a list of networks should appear, and select the network that you are trying to connect to. I recommend you also look through the troubleshooting guide.
Punteggio 0
Aggiungi la tua risposta
Selamawi Ambaye sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 647
