Salta al contenuto principale
The Canon EOS 300D is a 6.3-megapixel entry-level digital single-lens reflex camera.
Why doesn't camera recognise a memory card is inserted
Camera is not writing files to the cf memory card and is saying a card is not inserted.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
maybe contacts are greasy. try to degrease it, any white spirit/alcohol will do. also, you might need to format/reformat the memory card using camera...
Punteggio 0
Preparati per le riparazioni future
I've also discovered that this happens because of a bent pin in the camera where the CompactFlash card plugs into the camera. Mine has been the two pins closest to the eject button.
Punteggio 0
This can also be caused by a defective/broken CF door switch
Punteggio 0
Could it be for any other situations, as I have done all checks and keep the problem.
Punteggio 0
Aggiungi la tua risposta
Rob sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,696
