Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Is a LogicBoard Upgrade possible
Now using a beautiful black A1181 2GHz Core Duo MacBook. Like to know if a 2GHz or better Core 2 Duo Logic Board (A1278) can be built in instead of the original one. Thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Its not a direct fit, Other items in the Macbook need to plug into the logic board, such as the fan, inverter cable, these have different connections between the 2 Models. Generally not worth the money unless parts are super cheap or free. for the price of the logic board, fans, cables, etc. you could probably find a whole used Macbook.
Punteggio 2
1 Commento:
Didn't realize A1278 was for a unibody macbook - will not work at all.
da
Parti & Attrezzi Popolari
Acquista tutti
As Matthewfrey said well, they are unfortunately incompatible. Actually, there isn't a single connector on the board that is compatible, so you would be rebuilding an A1178 machine from parts (which is so much more expensive than just purchasing a complete machine).
Sorry!
Punteggio 1
Aggiungi la tua risposta
Chris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,355
