Salta al contenuto principale
The Roku 3 (Model: 4200) is a third generation streaming device released on March 5, 2013. Connect to any television or video display with correct input connections to stream available content.
controller will not work
my roku 3 was working fine. then the controller quit working. I put new batt. in it, did not make a difference. Then I pulled the power cord from the unit. Thinking it would reset it self, it worked for several clicks then quit. What should I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
Try this trouble shooting guide: http://mkvxstream.blogspot.com/2013/01/s...
Punteggio 2
Parti & Attrezzi Popolari
there was small issue in this http://www.showboxmovies.org
Punteggio 0
If the controller is working randomly the problem is most likely the carbon contacts on the back of the rubber pad inside are covered with food oils and debris. When the buttons are pressed the dirty contacts remain open. Carefully disassemble the hand piece watching where everything fits. One screw behind the batteries and snaps around the perimeter hold it together. Clean everything with alcohol and hand soap, except the circuit board, then dry thoroughly before reassembly.
Punteggio 0
Aggiungi la tua risposta
mgopp sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 210
