Salta al contenuto principale
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
Screen is not as bright
I had to replace my complete screen ( touch digitizer and LCD screen).I. put it back together and it came on but noticed screen was not as bright even though brightness controlled all the way up.If I put it on auto bright you can barely seen the screen. I doubled check the LCD ribbon and seem to be in good. Any ideas on what could be the problem.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Not sure who you got your screen from but sometimes there's a protective film on the screen that's tinted you need to peel off. Ive made that mistake once myself.
Punteggio 1
3 Commenti:
No I removed that
da
My screeen became dim after I upgraded to 10.1
da
@rouadi1 In your case I would check my settings in power settings and in the display settings. Sometimes upgrades change default settings
da
Parti e strumenti correlati
Acquista tutti
Its your front camera flex cable (there is proxy on it) and this proxy didnt recognize light propertly
Punteggio 1
Aggiungi la tua risposta
Arletta sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,612
