Salta al contenuto principale
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Why is this device ghost touching after replacing the screen?
I replaced this iPad Mini 3 with a new screen from iFixit and the customer brought it back saying that it was doing things on it's own without her even touching it. I confirmed that is the case and it seems to be happening when a slight bit of pressure is applied to the lower left or right corners. I took a video if you would like to see it happen. I opened it up again and nothing looks pinched and I put some EMI tape over the home button cable, since I read that may help. ANy ideas here? I also ordered a new screen in case I have to go that route.
Thanks in advance!
Bodhi
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Have you confirmed that the cable for the digitizer is seated correctly?
Also, I have heard that a power cycle may also fix the problem sometimes.
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
I have the same problem with an iPad 3 4G... Even when the digitizer isn't touching the frame the iPad goes crazy. I've tried different digitizers from different companies but still having problems. I know the solutions for the iPad mini 1 and iPad air but with this one i'm stuck... Anyone?
Punteggio 0
I too just posted this similar question on fixit and i'm in the same boat and no one seems to have a fix for this. We order our parts from china and are the same that many companies sell here in the states. I have contacted my supplier about this issue he stated I should try OEM original apple screen for the iPad mini 3. So on my next order I'll be ordering some. I'll report my outcome.
Punteggio 0
1 Commento:
I think it's just bad quality batches of digitizer glass touch screen. I've been repairing many iPad Mini 3's without issue using Kapton tape as a safe measure.
da
Aggiungi la tua risposta
Mac Daddy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 441
