OTG support through USB
How can OTG function for the usb port be activated so that USB drives and other devices can be used through the usb port?
Questa è una buona domanda?
Usually you need a compatible OTG cable or dock for your device. An OTG cable is different than a normal USB cable. An OTG cable has the sense pin shorted to the ground pin, while a normal USB cable does not. Some manufactures may use a resistor of a certain value to short the sense pin to the ground pin. This tells the device to enter USB host mode when an OTG cable is connected. So if you have a compatible OTG cable you should only need to plug in the cable for the device to activate USB host mode (OTG). Plug in your USB device to the OTG cable first then plug the OTG cable into your tablet. If this does not work then you may want to let me know what version of Android you are running and what kernel it uses. You can find this information in the settings menu under About tablet. Or you can do a search to see if the kernel you are using has OTG function or not included. I am going to guess your kernel does have it but it may not hurt to check if you can not get the tablet to enter USB host mode(OTG). There are also some apps from the Google Play Store that may help troubleshoot your OTG issue, just type OTG into Google Play search to find some. Hope this helps.
I have Android 4.42 rooted Kernal 3.10.0-5332174
dpi@swdd6219#2 -Mon Jul 6 17:52 kst 2015
I have OTG cables that are recognized on my Android phone but do not get recognized on my tablet. I have use Google play apps they have helped to identify that cables are not recognized. I added two hardware files to permissions/ subdirectory.
This tab uses the Marvell PXA1088 quad core processor. From my understanding this processor may not be capable of OTG because of hardware limitations. Not sure this is true because Marvell specs for this processor say it is capable of USB host mode. Until a custom or updated kernel is released there is currently no OTG capabilities for this tab, or at least the WiFi only, and 3G models. The 4G/LTE model I have heard has a kernel for OTG capabilities but I am not sure if it is the stock kernel or a custom kernel. So hopefully in time OTG capability will come to all versions of the galaxy tab 4 7.0.
I have galaxy tab 4 rooted with android 4.4.2 with kernel 3.10.0-5856261
I have a Samsung Galaxy Tab 4, Android 5.1.1, Kernel version 3.10.49-5869642 and I can't get otg features to work either.
I have Samsung J5 with similar problem. I have an USB camera which when I plug it in, and use the OTG trouble shooter, it says OTG recognised, USB Device NOT recognised, it then says 2 USB hubs detected. Anyone help pleae?
The Galaxy Tab 4.7.0 only supports OTG on the LTE version… Sorry guys…
check for power supplied by the phone through the OTG Cable
@Ejim Malachi
Try starting the tablet in safe mode and check if it works OK.
If it does a "downloaded" app is the cause of the problem.
If still no good use a magnifying glass and a strong light to visually inspect the USB port to make sure that there is no dust or lint trapped in the enclosure and that ALL the pins (5) are there, (especially pin 4 as this is the 'sense" lead) and that they are straight and parallel with each other.
If there is anything trapped in the port enclosure preventing a good electrical connection, do not use a metal pin or probe to get it out, use a wooden toothpick or suitable plastic probe to gently pry out the obstruction.
Ok I'll try it straight away. Thanks
Its root fault… Stock kernel fixes all
Ultime 24 ore: 1
Ultimi 7 giorni: 22
Ultimi 30 giorni: 48
Tutti i Tempi: 83,264
13 Commenti
iff i do a new widow my usb use goo?
da Aizaz baloch
I have Samsung tab 4 kernel 3.10.0-7252309
da Rishabh Shah
I have a samsung galaxy tab e with android version 4.4.4 When I connect otg flash, it will display usb connector connected and nothing else will show up. It wasn't like this before
da Ejim Malachi
Sorry version 4.4.4
da Ejim Malachi
@Ejim Malachi ,
Does the OTG flash work OK on other android devices with OTG capability?
da jayeff
Mostra 8 altri commenti
