Salta al contenuto principale
First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
How to replace the storage module?
I didn't notice in the teardowns where the storage module was (16Gb/32Gb/64Gb)...did I just miss that and how would you replace it?
Thanks.
K Martin
Questa è una buona domanda?
Punteggio 2
1 Commento
Good question
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
In the tear down, the memory was on the Logic Board, so technically, you could, but you would have to replace the entire logic board to do so. I don't think it would be worth it.
Punteggio 3
1 Commento:
Yup; it's not possible, it's soldered down to the board. BGA, at that.
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Kevin Martin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 17,137
