Salta al contenuto principale
The Microsoft Surface Pro 2 is a Tablet/Laptop fusion that was released in 2013. The Surface Pro 2 is the successor of Microsoft's Surface Pro and uses Windows 8.1 through Windows 10.
Domanda Chiusa
having Touch screen problem
After I dropped my unit last night, the bottom 2 cm of touch screen has stopped functioning. Any suggestions?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Either the digitizer was damaged, or the impact of the drop caused the cable to get knocked loose. Either way the device will need to be opened in order to determine the issue. While nowhere near as big of a pain as the surface pro 3, the pro 2 is still one of the more difficult tablet repairs and shouldn't be taken lightly.
Punteggio 0
1 Commento:
Hey ... thanks @RegencyTech... Immediately after the drop, many touch points on the screen were active and that part later stopped working. So I think there is a problem with digitizer.
da
Parti e strumenti correlati
Acquista tutti
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 128
