Salta al contenuto principale
Why is my drone not flying?
It starts but won't take off?
It just flips over on the wheels and by itself it just dosent go up?
Questa è una buona domanda?
Punteggio 13
8 Commenti
Mine has the same issue, its like the propellers are revered. It wont take off, it will only only push downward into the ground, its unusable!
da
I have the same issue
da
same issue anyone know why?
da
me too it just spins backwards all by itself when you take it off on the weels for a few seconds and i think it has to do with balanced weight but at the moment im still trying to figure out whats wrong
da
da
Mostra altri 3 commenti
Aggiungi un commento
12 Risposte
Risposta Più Utile
The proppellers are mounted in the wrong order. Switch left and right propellers front and back. Had the same problem. The drone was pushing down instead of moving up
http://blog.parrot.com/2014/07/24/how-to...
Punteggio 6
4 Commenti:
Hi thanks God bless you it works i thought my new drone was spoilt i came here read your started my drone and it came i recommend this to everyone IT WORKS
da
hello, thank you your suggestion works
da
Thanks a ton! UDAMAN
da
Top man. It's working now :)
da
Two propellers angle up and two angle down. Align then in a cross cross pattern so:
front left angle up - front right angle down
back left angle down - back right angle up
Punteggio 4
3 Commenti:
Thank you so much. This is exactly right!
da
OMG this was helpful!!! Thank you!!!
da
Thanks it works perfectly
da
Keep switching the propellers and trying it until you get the correct order
Punteggio 2
1 Commento:
ok thank you
da
But I figured it out one of your PROPELLERS might be WEAKER than the other ones allowing it to be UN-EVEN. For mines that's what it is but I might need to buy new propellers if you can do that
Punteggio 0
1 Commento:
i bought new propellers it still doesn't work
da
yes thats all it does and dont come off the grown just flips foward
Punteggio 0
My drone typhoon h is not responding to the monitor
Punteggio 0
My typhoon h drone camera is nor responding to the monitor
Punteggio 0
No.it goes on it's side. And doesn't fly. It's not mine. It's a friends drone I was using
Punteggio 0
The wings are rotating but it doesnt fly
Punteggio 0
I had the same problem. I had to put the propellers on again after a crash and I just installed them on the wrong motor. Once in the right position it works like it’s supposed to. Good Luck!
Punteggio 0
Check the direction of the props. They might have gotten reversed and the 2 same angle props go diagonally to each other
Punteggio 0
if you press the takeoff button then try lifting up it should work
Punteggio 0
1 Commento:
my parrot rolling spider never failed so theirs should be a priority
da
Aggiungi la tua risposta
Isaac Papasidero sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 17,893
