Salta al contenuto principale
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
My MacBook isnt turning on
Hi everyone,
i Have an Old mac book Pro which i bought in 2010 and has served me very well till date. For the past 6 months its not turning on when i press the power on button.
Prior to it going cold.. the charger always showed a orange light instead of the green one which is usually present when charging.
i have shown it to a number of apple guys and everone says that it requires the charging port which needs to be replaced but supposedly we cant get the parts.
i want to know is charging port the same as DC port and how can i fix my laptop.
thanks for the help !!!!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
If the light isn't making the change from green to orange, that means the Logic Board isn't getting the charging status from the battery itself. This could also be causing the lack of powering up. First bit of troubleshooting I would recommend is to open up the bottom and disconnect the battery cable from the logic board. Then plug the MagSafe adapter into the machine and attempt to power, if it powers and starts up that tells us it's the battery. In which case MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Battery
And use this guide for it: Sostituzione batteria MacBook Pro Unibody da 15" versione metà 2009
If it does not follow this next step: Keeping the batter disconnected, locate the keyboard ribbon cable and GENTLY disconnect it. Plug the MagSafe in (don't be alarmed as it should power itself up). If it does the there is is an issue with the keyboard (I've seen this odd situation time and time again).
Please remember to take all safety and ESD precautions before attempting anything you're not comfortable with! Let us know if either of these two things diagnose the issue, if not there is a bit more we can do to troubleshoot :)
Immagine Replace a 7080 mAh battery compatible with MacBook Pro 15" Unibody (Mid 2009/Mid 2010). 77.5 Watt Hours (Wh), 10.95 Volts (V).
Prodotto
$89.99
Punteggio 2
2 Commenti:
sorry, its a very dim green light when I plug the power adapter to the notebook
da
Do you have another MagSafe that you can test with?
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
KG sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 385
