Salta al contenuto principale
Smartphone release by Sony-- also known as Sony Xperia Z1 Honami, Sony Xperia Z1 C6902/L39h, Sony Xperia Z1 C6903, Sony Xperia Z1 C6906, Sony Xperia Z1 C6943. Released in September 2013.
How to replace battery?
My Xperia Z1 power off because the charge is ended but on screen the software is still indicating 70% of battery.
I think I should replace the battery...
Can you explain me how?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Luca Mino follow the instructions from the service manual to remove the battery.==>> Z1-Battery.pdf<<== the last step has been omitted. It should be"remove the battery"
Punteggio 1
Preparati per le riparazioni future
Acquista tutti
Follow this guide.
You can use a hair dryer instead of heat gun, and dont heat the back cover too much.
Punteggio 0
Aggiungi la tua risposta
Luca sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,514
