Salta al contenuto principale
A popular graphic calculator released by Texas Instruments in 1996.
How to remove back cover?
I have a TI-83 graph calculator (not TI-83 plus), I think, by (c), it's from year 1996.
On the back cover I only see two screw (not 6 as I see here in another teardown). I have remove that 2 screw but can not remove the cover. How can I release the back cover, without broken it ? Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
At the bottom, by the data port, you can get a small screwdriver or plastic tool in the seam on both sides. Then just cautiously work your way around and toward the top; there are some snaps which will come loose.
I had the same issue with mine and got so frustrated that I just didn't care anymore if I broke it! It turns out that was the way to go.
Punteggio 0
Parti & Attrezzi Popolari
Aggiungi la tua risposta
luisfiliperibeiro sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 4,396
