Salta al contenuto principale
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
20 Domande Visualizza tutte
Why can't I install the usb driver?
After installing windows 10 there were a couple missing drivers. I troubleshooted the laptop in devices and printers and it fixed all the driver issues except for the USB2.0-CWR driver. It says it doesn't have it. I tried to update it from device manager but it says windows can't find the driver, go to the manufacturersame website. I couldn't find it on dell.com either. What should I do?
It says in properties that the drivers for this device are not installed. (Code 28)
Questa è una buona domanda?
Punteggio 0
3 Commenti
have you updated windows 10 yet it could help
da
I'll try that thanx.
da
Ran a bunch of updates. Didn't change it. I had a problem on an hp pavilion recently where it didn't recognize the DVD drive. It seemed like a driver problem but was actually something in the registry that needed deleted and then it worked fine. Could this be something similar?
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Hi,
Did you try this link, scroll to bottom and download Realtek USB 2.0 card reader?
http://www.driverscape.com/manufacturers.... If you have please ignore.
Punteggio 2
1 Commento:
Thanks, Jayeff, your link worked great.
da
down load driver genius it should find the driver.
Punteggio 0
Hey! It is easy! If you can't download drivers from official website, you can try to use a 3rd-party driver program to download driver for Windows 10. More detail: http://goo.gl/5h6ICN
Punteggio 0
maybe you should look for the driver Sesua, try visiting http://www.aiydriver.com and find your laptop drivers
Punteggio 0
Aggiungi la tua risposta
Jesse sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,584
