Salta al contenuto principale
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
20 Domande Visualizza tutte
iPad 2 black screen
My iPad 2 screen went black... i see it's turn on... back light but no image. Hard reset won't do nothing. When i do a screen capture i momentarly see my screen a little...
I tried to to hit it a little like i saw in some messages but it's doing nothing. Any help please?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Yeah, your backlights out. Not super big on iPads. But, I think you just need to replace the LCD.
iPad 2 Wi-Fi EMC 2415 Front Panel Replacement
iPad 2 LCD
Immagine Replace a screen compatible with the A1395, A1396, and A1397 model 2nd Generation iPad tablet. Part #L097X02. 9.7". 1024-by-768 resolution, 132 pixels per inch (ppi).
Prodotto
iPad 2 LCD
$59.99
Punteggio 2
It's likely that the iPad will need to have the lcd cable reconnected. Sometimes smacking the back doesn't work. With the proper instructions And patience you can open the iPad and do this. Be sure to power the iPad off first though. Just hold the power button for about 5-10 seconds then swipe not the screen towards the top where slide to turn off would be. You should see the backlight dim slightly then turn off.
Follow the ifixit guide to open an iPad 2, and you'll be good to go.
Punteggio 2
Didn't work, followed the procedure and did what was required with no changes. Still a dark screen.
Punteggio 0
Aggiungi la tua risposta
martinesabourin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 855
