Salta al contenuto principale
Stylish Android tablet manufactured by Acer. Released February 2014.
Why does my device not turn on?
When I try to turn on my device it simply does not respond. I've tried charging it and still get no response.
Questa è una buona domanda?
Punteggio 6
2 Commenti
my i phone 4 will not turn on what could be wrong i have a new battery in it
da
i have the same problem with my acer iconia A1-830, is doesn't turned on and is not charging i do not know what i need to do with it.
can some one give i solution if you can.
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
There are several reasons for a device not turning on or not charging. One is that your charging cable could be broken, try charging it with a different cable. Sometimes dirt can get inside the charging port or cable. Try cleaning the charging port and cable and then try plugging the device back in. Your battery could be completely depleted of energy and may not charge even when plugged in. In this case the battery needs to be replaced. There can also be water or dust damage within your device causing a short.
Punteggio 5
1 Commento:
Thank you fro your help I will try these option and I will let you know
da
Parti e strumenti correlati
i forgot the password and can,t open my table hoppe you can help
Punteggio 0
I forgot my password and can,t open my tablet
Punteggio 0
Hello my device model is B1-830 very similar to this, I tried to root it and it got bricked and bootlooping then I tried to formatt it and now my pc doesnt recognize the tablet and it doesnt turn on do you have any solution?
Punteggio 0
Aggiungi la tua risposta
Matt Champagne sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,251
