Salta al contenuto principale
La versione del 1998 si ispira alla Beetle originale ma, in confronto con il modello vecchio, è molto più spaziosa e ha caratteristiche molto più avanzate.
Trunk will not open at all
I have a 2003 VW Beetle Convertible. The trunk latch is broken. I cannot open the trunk with remote or key. I opened the rear seat to gain access to the trunk, reach my arm in and the latch is broken. I know this because when I pull on the latch mechanism, it's frozen, will not move at all. Any suggestions on how to get into trunk when latch is broken in the closed position?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
The info in this link may be of interest
http://newbeetle.org/forums/new-beetle-c...
Punteggio 4
2 Commenti:
It's a really tight fit. In fact the only way I can work on the trunk from the inside is with one arm reaching into the trunk area, rest of my body outside on the back seat. I discovered a round (almost invisible) cap of sorts inside the trunk below and to the right of the emergency release level. From the article you attached I see that this should be another release (a more effective one). I will try it later today. Thank you for the article.
da
This does NOT work for an 2003 Beetle 1.8T.
da
Aggiungi la tua risposta
Jim sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 12
Ultimi 30 giorni: 47
Tutti i Tempi: 45,783
