Salta al contenuto principale
La versione del 1998 si ispira alla Beetle originale ma, in confronto con il modello vecchio, è molto più spaziosa e ha caratteristiche molto più avanzate.
33 Domande Visualizza tutte
Trunk will not open at all
I have a 2003 VW Beetle Convertible. The trunk latch is broken. I cannot open the trunk with remote or key. I opened the rear seat to gain access to the trunk, reach my arm in and the latch is broken. I know this because when I pull on the latch mechanism, it's frozen, will not move at all. Any suggestions on how to get into trunk when latch is broken in the closed position?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
The info in this link may be of interest
http://newbeetle.org/forums/new-beetle-c...
Punteggio 4
1 Commento:
It's a really tight fit. In fact the only way I can work on the trunk from the inside is with one arm reaching into the trunk area, rest of my body outside on the back seat. I discovered a round (almost invisible) cap of sorts inside the trunk below and to the right of the emergency release level. From the article you attached I see that this should be another release (a more effective one). I will try it later today. Thank you for the article.
da
Aggiungi la tua risposta
Jim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 122
Tutti i Tempi: 42,648
