Salta al contenuto principale
Third generation Surface Pro tablet, released June 20, 2014.
What is the version of my LCD screen?
Hi everyone,
The touch screen of my Surface pro 3 was broken so i tried to take off the touch screen from lcd but I did not succeed to save the LCD. So now, i try to buy a new one but i don't know the version of my lcd because I inconveniently threw the flex cable between the touch screen and the motherboard. So, is there anything i can do to know the version of my current LCD ?
Questa è una buona domanda?
Punteggio 3
2 Commenti
same, I have a surface 3 that I recently broke, but I don't want to open it without having a replacement screen first, but I don't know which version I should get. any way of knowing how to tell which version it is by the outside?
da
Any luck with identifying the version?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
The model number on my Surface Pro 3 is written in very faint writing on the underside of the kickstand.
Mine says Microsoft Corporation Model: 1631
Punteggio 2
Parti & Attrezzi Popolari
Acquista tutti
If you type in the actual model number which is on the back of the device you will be able to get a screen type by just typing in #### replacement screen. That will get you the exact replacement screen. For a Surface Pro 3 I think they are all 1631 screens. Look on the back and see if you see Model # 1631. If not just replace your model number in the #### spot.
Punteggio 0
3 Commenti:
Type in actual model number where?
da
I too need to know where I can type in the actual model number.
da
google: 1631 replacement screen
da
Aggiungi la tua risposta
Gaetan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 4,818
