Region code incorrect message
I changed the driver in my PlayStation 3 now every time I put a movie in I get this message that says region code is incorrect what do I do
Questa è una buona domanda?
It can be a different default region code of the driver which is not compatible with the movies. You should be able to change the region code of the drive for up to 5 times. So change the region of the driver to your place. If you can’t, you can also change the region of the DVDs. Here is the complete guide, check more details
Parti e strumenti correlati
Acquista tuttiUltime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 132
i think it has to do with the Blis vs Bles thing if you used a driver containing a file with one of these you might have to replace it with one of the other kink.
da waagosh3
