Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
Domanda Chiusa
Why isn't my vibrate function working when called?
In the sounds settings I switched my vibrate to on when ring and when silent, and I can feel the phone vibrate when the switch is set to vibrate from ring, but when I'm being called it won't vibrate, nor when texted. I've tried a hard reset, and this is a brand new IPhone 6 plus that was sent to me because my last one had the exact same problem.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
If it's still under warranty. Repeat the process, it's your best guest. ( send it again )
It's proably a defect parts or software that cause the issue.
Whatever it is, the Apple Warranty covers it!
Good luck!
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
Go to settings,then click sounds then check and see if you vibrate when ring and vibrate on silent are activated if not then activate and your are good to go!
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 6,074
