My battery life has reduced significantly.
My battery life percentage runs out more quickly than it used to. Why is that?
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
The battery after many charge and discharge cycles will lose it's ability to hold a charge. Extreme changes in temperature can also reduce battery life, as well as keeping it plugged in all the time. You should let the battery completely discharge once and a while to help it have a longer life. If the battery is unusable for your needs, you should replace it.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 380
