Salta al contenuto principale
10.1" tablet released in February 2014, powered by a custom version of Android 4.4 KitKat, and identified by model number: SM-T520NZKAXAR
20 Domande Visualizza tutte
Why isn't my tablet making any sound?
My tablet isn't on mute or silent, and my volume button works and is turned on. However, it isn't making any sound or noise at all no matter what I do.
Questa è una buona domanda?
Punteggio 20
2 Commenti
Did it get dropped
da
I did not drop it
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
If it's a software issue; you can do a soft reset by holding down the power button for 8 seconds until the device turns off. If that method doesn't work you can do a hard reset of your device but make sure to perform a backup so you wont lose all of your data. If that method doesn't work you can put your device into recovery mode by holding these buttons at the same time while your device is off; power button, volume up, and home button. Use the volume button to scroll and select the option wipe device/factory reset. Then select all user data and press the power button to confirm. If this method doesn't work you might have to replace the motherboard. You can find replacement guides for the device on this page.
Take a look at this page if you come across more problems on your device.
Samsung Galaxy Tab Pro 10.1 Troubleshooting
Punteggio 3
3 Commenti:
Thanks for your answer my device it perfect again I was so upset when it lost volume when I was in lock down due Corona Virus inside house
da
Where is the power button.
da
-_-‎‎‎‎‎‎‎‎‎‎‎‎
da
Why is my &&^&^$^ tablet working
Punteggio 1
Kids e dong have sound either
Punteggio 1
Aggiungi la tua risposta
Stephen Yeung sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 22
Tutti i Tempi: 22,928
