Salta al contenuto principale
Improved second generation Google-branded tablet with a 7" screen.
Automatic screen rotation not working
I've had a Nexus 7 Gen 2 for a couple years now, and recently, the screen has stopped rotating in response to device orientation. Restarting the device used to fix the issue temporarily, but now even that doesn't always work. This also affects tilt functions in various games.
Check My Android reads 0 on the tilt sensors when the device gets stuck. I use Rotation to manually shift the screen, but this problem occurs with or without the app installed.
Any suggestions as to what might be wrong and how to fix it?
Questa è una buona domanda?
Punteggio 19
13 Commenti
Fixed! Thank you!
da
I have a problem with my Nexus photo editing..won't work & screen goes darker..who could I call? Thanks
da
I had this problem caused by a conflict with Spotify app. Uninstalling and reinstalling Spotify cured it
da
SOLVED! I had this problem,
- Turned the screen rotation off from pull down top menu
- Powered phone off
- Rebooted phone
- Turned Screen Rotation back on from pull down top menu
da
Worked like a charm!
da
Mostra altri 8 commenti
Aggiungi un commento
9 Risposte
Soluzione Prescelta
This may help
https://www.youtube.com/watch?v=LLCAeBe2...
Good luck
Punteggio 9
10 Commenti:
Thanks! I'd tried this before, but this time I used a few pieces of sticky tack to keep the ribbon in place. The fix actually held this time!
da
Nexus 9 Tablet Auto Rotation Fix
Try the following link: it works!
https://www.youtube.com/watch?v=CbGi0yoh...
Details:
Check first that "Auto-rotate" is turned "on", and does NOT work. Then:
1. Go the apps screen
2. Open up: Google
3. Got settings: top left three bars, the "settings"
4. Select Now Cards
5. Under Show Cards: De-select (turn off "Show Cards")
6. Turn off Nexus 7, and Restart.
7. Make sure "Auto-rotate" is turned on.
8. Auto-rotation will work again! (on most Nexus 7 tablets?, if it still does not work, "uninstall" Google Now all
together, and reboot. If you re-install Google Now later, and set it up, and reboot,"Auto-rotate will still work)
9. No need to tinker with the hardware, and open the tablet!
10. Spread the word.
Technical details:
When Autorotate does not work:
All my tablets are running Android version 6.0.1.
Kernel build: 3.4.0-g09a22c6
android-build@wpdv14.hot.corp.google.com #1
Wed Apr 20 00:06:25 UTC 2016
Build Number: MOB30M
da
This worked for me -- Thanks!!
da
This just worked for my Nexus 10. I had to turn off my Google feed altogether.
da
I have Nexus 7 and bad the same problem, I installera "check my android" and verifiera that is was a hardware kanske. I was not able to open it up like in the the video to fix the Contact, but instead this:
1) Watched this video to get än idea where the contact is located.
2) Pressed very hard on the backside just above the contact.
3) Rebooted the Nexus 7.
Now the automatic rotation worked again :-)
da
Mostra altri 5 commenti
Parti e strumenti popolari
Acquista tutti
Details:
2. Open up: Google
4. Select Now Cards
Technical details:
1. Download and install: Check My Android.
2. Open the App
3. Select: "Sensor"
4, You will see that the following sensors are disabled, or do not work:
1. MPL Accelerometer
5. MPL Gyroscope
7. MPL Gyroscope
5. Turn off the "Now" cards in Google, as above
6. "Auto-rotate will work again.
7. Sensors 1, 5, and 7. will work again.
8. Interesting note:
If you turn on the "Now" cards again, in Google. Power down the tablet and resart. The "Auto-rotate" keeps on
working (ONLY ON SOME NEXUS 7 TABLETS (I have 5 of them, some work, some not)), and all sensors show OK? For now at
least!!! No idea why??
To play it safe, just turn of the "Now" cards, (or uninstall Google Now), and reboot!!
Peter
20 June 2016
Punteggio 8
7 Commenti:
Autorotation suddenly stopped today on my Nexus 7 and this fixed it - Thanks
da
I went to the menu as directed above and my screen does not show a menu item, 4. Select Now Cards
da
Worked perfectly for my Nexus running Marshmallow. Thank u so much.
da
This worked for me. Thanks
da
Disabling Google feed also worked for me (Nexus 7 2nd generation). That's weird though!m
da
Mostra altri 2 commenti
I was able to resolve this by simply squeezing the screen and back plate together with my fingers.
Punteggio 2
6 Commenti:
Tried this AFTER uninstalling multiple apps, including Google Now.... Only to find out THIS REALLY WORKS...! Thanks for the suggestion...
1) shut down Nexus 7 all the way
2) removed from it's leather case
3) placed it face down on a cushioned, flat surface
4) pressed down, with pretty good amount of pressure, across every square inch of the tablet - 2 or 3 times for good measure..
5) voila..!!
da
Ruben, thank you very much. It really works. I didn't need to deactivate anything and auto rotate is working now.
da
This is what worked for me. I used the Check My Android app from the Play Store to verify that the accelerometer was not working. I then did the press down treatment (resulting in several cracking sounds) and voila the auto orientation worked again.
Thanks
da
Thanks, when none of the setting changes worked, I tried pressing from the backside for 2-3 times , auto orientation started working :).
da
Wow. I was skeptical but this worked!
da
Mostra 1 altro commento
Work for me thx alot
Punteggio 1
1 Commento:
Worked for me!
da
Wow .... Back press trick fixed autorotation AND not booting without charger plugged in. A bonus !!!! Thanks !!!!
Punteggio 0
amazing ! it worked for me as well by just pressing the back. thanks
Punteggio 0
I used the Check My Android app from the Play Store to verify that the accelerometer was NOT working. I then did the press down treatment (resulting in several cracking sounds) and voila the auto orientation worked again.
The press down treatment is to put the tablet on a flat surface screen down then press firmly with a thumb all over the back side. I pressed once every square inch.
Punteggio 0
Banging it, restarting and rebooting (holding power button down) did not work for me.
I downloaded an antivirus software and cleaned out my tablet. It asked me to remove some possible apps (mine was towelroot). After cleanup, I restarted my tablet and auto rotation WORKED AGAIN.
Maybe it was a virus or a corrupted application that helped me once before to connect my keyboard. But anyway, after removal, my keyboard and all the functions on my tablet worked.
So try using the antivirus and restarting it as well.
Punteggio 0
This is a hardware issue. You need to remove the back cover and remove and reseat the larger ribbon cable. This will fix the issue 100%.
Punteggio 0
Aggiungi la tua risposta
DJZephyr sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 76
Tutti i Tempi: 160,250
