Salta al contenuto principale
The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
20 Domande Visualizza tutte
Ipad a1403 wont rotate after replaceing the glass digitizer
I recently fixed the Glass on my ipad a1403. After doing so my Ipad will not rotate. I checked the settings and the rotation lock is not on. Any suggestions?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
There is a sensor inside that determines the orientation of the screen, it would be around the screen not on the board but attached by cable. It may have come loose during the change over.
You will have to open it again to check.
Good luck.
Punteggio 1
Okay thank you I will give that a try do you know where the sensor is located on the screen like a rough general location?
Punteggio 0
Aggiungi la tua risposta
zk0123 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 176
