My buttons won't work
When I turn my calculator on, the calculator will not recognize when I push any of the buttons.
Questa è una buona domanda?
unknown, I'd start with some basic trouble shooting. Remove the internal battery for a minute or two. If there are not results with it try to
- check for a stuck key
- reloading the software
- open up the unit and shake it out in case something is blocking the key contacts
- clean the circuit board contacts under the keys with an eraser
After that you are in for deeper testing. you would need a multimeter to check the resistance between the opposite halves of the keypads. For that you would of course remove the membrane. Low resistance between the two halves would indicate that it is shorted somewhere and would be interpreted as a stuck key. Use this guide to get to the keypad.
Thanks for the suggestions - under the assumption it was a stuck key I spent a few moments "massaging" the keys, and after a bit, it worked just fine! Hope this helps someone avoid a more intense solution...
I followed these directions and the calculator is now working. My gut instinct was that using the eraser did the trick because none of the keys seemed to be sticking. I am pleased but surprised! Thanks.
Cleaned contacts first with eraser, then went over all the contacts with alchohol to clean them. I checked continuitiy and it seemed to work, and also checked resistance with respect to power. As power was only working button for me. I had around .7 ohms the whole way through every button up to 1.2 ohms. Sprayed all of the components with duster and went over all circuit board lines with qtip and alchohol. It worked. hope it helps someone else!
I have been searching everywhere for the answer. THIS was it! Cleaned the contacts with eraser and alcohol and voila! Works like new!
Thank YOU!
Parti & Attrezzi Popolari
Try pressing and holding the little reset button on the back of the graphing calculator.
My calculator had a blinking cursor but was not responding to any buttons and couldn't turn off (buttons wouldn't respond). After holding down the tiny reset button it reset with all the buttons functioning again.
Easy fix. Hope's this helps someone.
how do fix Casio HS-8LU
this should be a new question
Ultime 24 Ore: 9
Ultimi 7 Giorni: 101
Ultimi 30 Giorni: 474
Tutti i Tempi: 74,048
3 Commenti
omg i cant stand this i cant get any answers to nothing everything I do or look up it dosent give me any answers does any one feel up to giving me any answers????
da Maci Padgett
Hi @tayco_queen1305 ,
If people knew what you wanted the answers to, perhaps you might get them.
What is the problem that you are having with your device, (besides getting answers)?
Please include make and model number and any relevant details such as what is or is not happening and what you have tried to do to resolve the problem if anything.
Post your response as a 'New" question in ifixit.
Linking it to a 3 year old post may not draw too many responses.
da jayeff
I had the same problem with my TI-84 plus silver edition. I took it apart and vacuumed it and cleaned it after that it is working fine. Be sure not to touch the circuits with your hand. hold it by the sides.
da Tareq Hasan
