Salta al contenuto principale
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Dualshock 3 right analog stick problem
My dualshock 3 right analog stick rotate in game camera by itself.Yesterday I was playing gta 5 suddenly the camera starts moving around the player then the same problem occurs during driving.I think that was a problem with glolame then I start last of us and same problem occur but it was more frustrating. It's making every game unplayable. I can't aim a weapon because aiming view get disturbes like i'm rotation right analog stick it's so much frustrating and silly please help me.
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
7 Risposte
Risposta Più Utile
Take it to gamestop and they will give you money for it and use that money to buy a new one. Trust me i had broken ps3 controllers and they gave me money for it.
Punteggio 1
Parti & Attrezzi Popolari
Acquista tutti
I just tore mine apart. I cleaned every contacts to be sure, but the solution for me was:
Blow in the sticks.
Yep, I removed the caps, turned the sticks in every directions and forcefully blown in in every directions. It’s like new now!
Punteggio 1
You have probably broken that analog stick, I have that problem too.
Punteggio 0
how can i fix this problem?
Punteggio 0
1 Commento:
idk i have the problom too
da
It seems to be a problem with the Dualshock 3 CECHZC2U A2 versions (the same ones that come with S3 Super Slim). My right analog sick drifts the camera upwards at the slightest touch and the left stick, if I move it slightly in the NW/NE and SW/SE directions, the character on screen will keep moving to the left.
It's annoying as !&&* in games witch require somewhat fine movement like MGS5.
But then again, when they are built as cheaply as they are, it'll start messing up quickly.
Punteggio 0
1 Commento:
Mine somewhat does that, but instead, on my right analog stick, when i move it left, the camera moves NW. When i move the stick right, the camera moves SE. But when i move the stick up and down, nothing happens. Does anyone know how to resolve my controller problem?
da
See this linkhttps://www.reddit.com/r/gaming/comments...
It worked for me. Might even work for you.
Punteggio 0
So a while ago I ordered two brand new dualshock 3 sixaxis controllers off of eBay. Now I'm having problems with both of them. When I'm playing NFSMW my car turns slightly right on it's own when I turn toggle stick isn't moving and when I'm planning MK 9 my character walks forwards or backwards on it's own when I'm not touching the d-pad. I have to beat the controller to get it to stop. Any ideas on what's going on with them?
Punteggio 0
Aggiungi la tua risposta
Parv Parashar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 28
Tutti i Tempi: 18,874
