Salta al contenuto principale
GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
Domanda Chiusa
ipad 4 is not charging
hi, i bought faulty ipad 4 gsm, it was not turning on and was not charging, so i heated its POWER MANAGEMENT ic and it starts up, but now problem is that it is not charging, i have replaced its charging port also, but it doesn't worked, while having closer look i observed that when it is connected its voltage regulator ic( Fairchild BCHAH/FDMC) is getting so hot and charger also gets hot.
plz see the image, the ic marked in black is getting hot.
i am thinking of changing pm ic, will it work???
Questa è una buona domanda?
Punteggio 0
1 Commento:
and can any one tell me location of u2 ic on logic board???
da
Aggiungi un commento
1 Risposta
U2 chip is the square black chip right able the charging connector.
in your case i would replace what ever thats getting hot because thats most likely whats being shorted.
Punteggio 0
2 Commenti:
can u upload any picture showing u2 ic, as m still unable to find it. or otherwise please tell the ic number of u2 ic so that i acn order it
da
u5900
please mark my answer as chosen if it helps and feel free to ask more questions.
good luck!
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,122
