Salta al contenuto principale
Samsung's second-generation smartwatch, released in April 2014 and powered by a Tizen-based OS. Model Number:SM-R380.
20 Domande Visualizza tutte
Samsung gear watch charger is not charging my watch.
My samsung gear watch will not take a charge, don't know wether it's the charger or the watch. I don't think it is the watch because it was working fine when it was charged. How much are the charges?
Questa è una buona domanda?
Punteggio 5
1 Commento
the contacts on the watch are scraped off. can I order the re64 board
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Same issue...my charging contacts on the back of the watch were worn away. From another thread I learned about the Circuit Writer, a pen that dispenses conducting ink. A drop on each contact and my watch charged again, and the pen was only about $12. Hope this helps!
Punteggio 4
3 Commenti:
What store did you get the Circuit Writer from?
da
Apologies for not responding sooner! I picked it up from Ama zon, was about $12.
I've used it twice more since I posted this, and my watch is still charging.
da
A follow-up: It's 8 months since I first used the Circuit Writer on my fading contacts, and have used it 5 times, and finally can't get it to charge any more -- I believe there just isn't enough of the original contact left for this hack to work.
So I ordered a brand new (old stock) Galaxy Gear 2 to replace my old faithful. $120 including shipping from Ebay, and it will be here tomorrow.
It was well worth extended the life of my watch by 8 months for $12, and still recommend you try the Circuit Writer trick! Thanks for following along.
da
Where can I send my samsung galaxy gear watch for repair? It will know longer take a charge.
Punteggio 2
the outer case of my gear 2 neo got broken. where can I find a replacement?
Punteggio 0
Aggiungi la tua risposta
wayne dozier sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 13,494
