Salta al contenuto principale
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
My Home Button Is Stuck In
One day I pressed down on the home button and it got stuck on the front panel. I have tried to get it out by pushing strongly on the button at different angles and that isnt working. When i took it to the apple store they told me they can replace the device but that would cost one hundred dollars for a swap. Is there some kind of fix for this?
Questa è una buona domanda?
Punteggio 4
1 Commento
I experienced this problem and the answers here were a great help! If you can't access Settings because your home button is gone/does not work, use a notification from the lock screen to open a program on the iPod, then ask Siri to turn on Settings. From there you can then turn on Assistive Touch and use that as your home button. This saved me from having to replace my iPod!
da
Aggiungi un commento
6 Risposte
Soluzione Prescelta
Hi, this is a very common issue.
You will need to disassemble the ipod by loosing up the adhesives at the bottom and separating the glass from the adhesives. Once that's done you can use a metal tool to un lip the plastic frame that holds the glass and lift it. You can reference the disassembly guide.
Then you will see where the home button used to be. There should be a little black dot which is normally glued to the yellow kapton tape.
If the dot is not there (which it sounds like it is not) you need to find it or find a replacement for it which you can then glue in the middle of the home button and after that it should click and will work normally after.
Punteggio 3
Parti e strumenti correlati
Acquista tutti
Risposta Più Utile
Go into settings on iPod touch and find assistive touch in accessibility and turn it on
Punteggio 11
10 Commenti:
You are a genius. Thanks!
da
Brilliant! Apple were quoting a ridiculous price for a potential fix and didn't even mention this as an option. Thanks!
da
thank you SO SO MUCH. I was having an anxiety attack, and once I tried this I felt better almost immediately
da
thx so much. I am forever in your dept. THANK GOD
da
Dude you are a fucken genius. I just discovered that my physical home button is not responding for some odd reason. Your suggestion just saved me from taking my iPod 5th Gen to the iFix Store to have it looked at. It would've been expensive to fìx as it's an "Apple" device. Thanks again
da
Mostra altri 5 commenti
You could take a toothbrush and brush along the crevasses. You could try it but it doesn't always work. Blowing air or using canned air could help too. I'm in the same situation right now but I've gotten nowhere. However, I intend on trying because I don't want to pay a hundred bucks just for a new one
Punteggio 0
Can someone post the disassembly manual please. I have the same problem and to be honest I do not want to spend $100 for something i can fix myself also wouldn't the broken adhesive have to be re-done?
Punteggio 0
1 Commento:
How do you click on settings if your button is not working
da
I used a little alcohol on a q-tip and applied just enough to the edge of the button that capillary action took some of the liquid between the button and screen surface without dripping any into the iPod itself.
Next, I cut a strip of very sticky tape (book tape) to the width of the button and about an inch long, trimmed it round at one end and stuck it to the button. Tape extending past the button (i.e. not directly over the button) was covered with paper so the tape only sticks to the button. With this long leader attached to the button, I held it in place with my thumb and ROTATED the tape (rotating the button along with it.) After a few turns, whatever dirt was holding the button in place was loosened and the button popped back out again. Now the button works perfectly.
If you found this post useful, take the money you would have spent on fixing your iPod, visit my website, and say thank you by buying my spinning top product:
http://www.spinny-doo.com
Punteggio 0
Thanks but this is not helping my ipod touch won't turn on and my home button does not work and this answer does not work
Punteggio 0
Aggiungi la tua risposta
Da SpoopySkeleton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 63
Tutti i Tempi: 44,737
