Salta al contenuto principale
NOKIA Model 3120b, Type: RH-50. The Nokia 3120b GSM cellular phone began production in 2004 but has been discontinued.
What is an application error?
Sir,
When I am using some applications on my phone the following error is occured on the screen.
"out of memory/java/out of memory"
I have sufficient phone memory and external memory in my phone.
What is an application error? Is there any limit for using applications in my phone? Please, give reply as early as possible.
Thanking You Sir
Questa è una buona domanda?
Punteggio 0
1 Commento
I also has the same problem on my nokia asha201 what should i do sir?please reply asap
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
the error showed on the screen is correct, the phone simply has not enough free ram to handle that application.
CLICK here for a few tips to free more memory
Punteggio 0
Parti & Attrezzi Popolari
Aggiungi la tua risposta
Venkateswararao M sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,612
