Salta al contenuto principale
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Domanda Chiusa
Detaching Digitizer on a Device Switched on
Greetings,
I have an iPad mini with a faulty logic board that I'm going to replace - it looks like the digitizer connector and / or near resistors / capacitors are damaged.
The problem is I'd like backing up the device before replacing the board and I have to type unlock code in.
Fortunately I can type the unlock code, but after that the screen goes mad - starts sporadically moving, being "touched" everywhere etc (Im aware of how to overcome "mad digitizer" problem and I think its not the case since Home button also doesnt work).
So, Id like doing the following:
  1. Start iTunes and plug the device in
  2. Type unlock code
  3. Detach the digitizer so that it doesnt interfere
  4. Do backup
The question is if detaching digitizer from a working device safe? I know I mustn't do this with the LCD since it kills the fuse, but what about the digitizer?
Thank you!
Questa è una buona domanda?
Punteggio 0
1 Commento
Please somebody help :)
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
No effect, if you detach only the touch screen. Don't go near the LCD. Use a plastic tool.
Note that usually crazy touch AND home button not working just mean you have a bad touch screens that needs to be replaced with a new good quality one.
You can make sure by trying on a known good screen.
Punteggio 1
1 Commento:
Thanks. I actually tried another logic board for which the digitizer works perfectly (home button as well),
da
Parti e strumenti correlati
Acquista tutti
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 106
