Salta al contenuto principale
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
I changed the keyboard
I changed keyboard in my laptop and now a screen comes up in blue saying something about drivers and something about new devices or hardware. Do I have to change any settings when replacing a keyboard
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
if rebooting it doesn't fix it, you might need to go on the manufactures site,ie:hp.com, and click on support, have your serial number ready and model number, go to drivers and software downloads, on the search bar, type in your model number and it should list all the drivers that your system requires. download them and follow the on screen instructions, you might have to unzip the files. then restart your system and it should be good to go if the keyborad is a good one.
hope this helps, if not, take it to abest buy and ask them for advise, they usualy tell you how to fix it if it is an easy fix.
good luck
Punteggio 1
1 Commento:
Thank you so much worked great
da
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
cherbear sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 45
