Salta al contenuto principale
The Baby Lock Ellegante 2 is a compact version of an industrial embroidery machine, produced by Baby Lock.
Using the extra large hoop
When trying to use the extra large hoop I keep getting a message to change to the extra large hoop and I already have that one attached. What can I do to make the machine recognize that I have the correct hoop?
Questa è una buona domanda?
Punteggio 1
1 Commento:
My machine does automatically select the hoop size in Edit mode and I verified the largest hoop was selected. I also make sure the design fits nicely with room to spare. I think something is wrong with my Embroidery unit that attaches to my machine because yesterday I was trying a design (in the mid size hoop) and the lettering did not sew in place...it went uphill. So I"m off to the shop with it. Thanks so much for your suggestions.
da
Aggiungi un commento
1 Risposta
Did you go to settings and tell your machine what size hoop you are using? The machine does not know what size you have attached unless you tell it. If you get too close or past the allowed area you will get the signal to change to a bigger hoop. Since I am new at machine embroidery I try to make my design just a bit smaller than the maximum allowed size to avoid this message.
Punteggio 0
Aggiungi la tua risposta
Jean Berch sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 710
