Salta al contenuto principale
A 7" tablet with a Android 4.2 (Jelly Bean) operating system.
Where I can get the firmware?
Hello, my tablet is bricked and not pass the logo of android, the firmware can not find it anywhere, I contacted the manufacturer but I do not want to provide the firmware.
Questa è una buona domanda?
Punteggio 26
3 Commenti
I have rca tablet its google sync how can I by pass do I install new firmwarew if so how
da
My tablet will not power on so the screen is blank
da
como consigo el sofwer de RCA RCT6272W23
da
Aggiungi un commento
8 Risposte
Risposta Più Utile
I made firmware this AM that fixed both of my RCA rct6387w2 units. It may help you too, but it restores to factory so your data will be lost.
Punteggio 11
4 Commenti:
Hello there.
I have the same problem.
The tablet doesn't pass the RCA logo
I hard reset it many times but its not result.
Can you help me?
da
where is this firmware
da
Can i get a link to a download for the firmware?
da
Parti e strumenti correlati
hello how repain firmware this tabletRCA RCT6272W23
Punteggio 2
1 Commento:
Como yo actualizo mi tableta a la última versión
da
Maybe look if Cyanogenmod is compatible.
Punteggio 1
3 Commenti:
What is Cyanogenmod and where can it be found? Maybe give a link.
da
CyanogenMod is a modded android rom, http://www.cyanogenmod.org/
da
si pero cual es el cm que debo descargar
da
Hi, after many hours into google, can´t find any ROM for this Tablet RCT6272W23
No luck with Rockchip Tools or BatchTools to erase NAND or flash another ROM all fails !!
Looking into FCC by the id in back , i find the HongKong manufacter, but no luck there.
Any info will be appreciated.
Regards
Punteggio 0
http://www.rockchipfirmware.com/sites/de...
Punteggio 0
1 Commento:
hola rommel mendieta: ese es el sofware de esta tablet RCA modelo RCT6272W23
da
igual me pasa los mismo
Punteggio 0
Try factory reseting the tablet go in to recovery mode by holding the power and volume buttons
Punteggio 0
please post for link of firmware
Punteggio 0
Aggiungi la tua risposta
ernestogarcia95 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 23,020
