Salta al contenuto principale
The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
I cannot enable WiFi on my phone
I can't connect to the WiFi even though the signal is really strong. Other people are able to connect to the same wi-fi.
Questa è una buona domanda?
Punteggio 20
11 Commenti
Can you connect to another person's Wifi connection? Or can a friend connect to your wifi network? It would be great to know if this is a problem with your home network, or a problem with your device.
da
Other people are able to connect to the home network.
da
Are you able to connect to another person's Wifi? This may be a hardware issue, but it's hard to say without removing some variables.
If you can connect to another person's Wifi, then there might be an issue with your router/device combo. If you can't connect to any Wifi Whatsoever, then chances are you have a hardware issue.
On a slightly related note, what version of Android are you running? Some OS versions of Android have had issues with connecting to Wifi.
da
Yes I have. I tried the answer below and it worked!
da
I can't see any suggestions for wifi networks in my HTC M9 mobile.. it's turned ON .. and u scan for networks and nothing shown ... please can you help me?
da
Mostra altri 6 commenti
Aggiungi un commento
12 Risposte
Risposta Più Utile
Try simply restarting you phone first. If this doesn't work, then try restarting your router/modem even though others can connect.
If neither of the previous suggestions work, then you might have a conflict with a 3rd party applications.
Try stopping any newly installed applications that might be running on the device. (With two fingers, swipe down from the status bar to open Quick Settings panel, and then tap Settings > Apps > Swipe to Running page > tap on the application you wish to stop > Stop)
http://www.htc.com/us/support/htc-one-m9...
Punteggio 5
2 Commenti:
By deleting the the recently installed app works. After I did that it automatically connected thanks alot
da
I have done all the tricks but not open WIFI in my mobile...
da
Parti & Attrezzi Popolari
Acquista tutti
Open backcover on your phone
Knock 5 time on your back camera
Again you can access this
Update (05/06/2018)
No need to root
Knock 5times on your back cameras
Plz like or comment if it's working
Punteggio 4
4 Commenti:
worked for me !! thanx!
da
it works for me...knock 5X...strange
da
work like magic, thanks for the helpful tips
da
Works great, but after I replace cover and restart it goes stops connecting to WiFi again and I have to open and tap camera again!
da
Hi. Lot customers have wifi problem on HTC devices with different models. I have One E9+ with wifi problem. Problem was sometimes wifi cant turn on. Sometimes is show that wifi is turned on but that cant find a wifi network. In other around devices thay can show few wifi networks but my htc doesnt. I try with soft and hard reset, doesnt help. I speak with man who repaired cellphones, he answer me that he seen lot htc phones with same problem. Now how i can fix problem instantly was clikcking with my finger on cover on behind ( battery cover, little bit down from camera lens) and after that wifi function work, but not to long mybe few hours. This is my 3rd HTC on 2 devices i have same problem one and one e9, with desire hd i have problem with gprs. I told myself its last htc device which i bought. Never more!
I send phone to official repairment, thay told me that was fisical damage and guarantie doesn cover. I cant belive because i save phone extremly.
Punteggio 3
3 Commenti:
Me also facing same problem with E9+.
Worst htc model.. this is my last htc phone for sure
da
Same problem with E9+ but solution worked
da
What a pity to by an E9+ and find out that a software update will never come. The WIFi does not work along with the Bluetooth unless I tap behind the battery...what a scam!!!!!...WILL NEVER BUY ANOTHER HTC & WILL NOT RECOMMEND TO ANYONE.
da
My phone get WiFi buat can't open anything
Punteggio 2
Yes i cant connect to a wifi .and others are connected
Punteggio 2
Had same problem with htc one m8s since marshmallow update, kept getting 'disabled' message and 'unable to connect' messages when trying to login to home WiFi but no problem on hotspots.
Noticed hotspots security mode were WPA2-PSK and home was WPA-PSK/WPA2-PSK. So I logged into my router and changed the security mode at home to WPA2-PSK and hey presto able to log in.
Just had to login again with all gadgets though because security mode had changed.
I had already rebooted phone and router and contacted htc support but none of these worked till I did above.
Punteggio 2
I have this problem too . I open my phone back and check everything is normal but WiFi and BT dosen`t work and still disable :( no more HTC
Punteggio 0
1 Commento:
reset battery it may help to resolve problem :)
da
7760116636 7760116636
Punteggio 0
try reset phone battery It may help to resolve the wifi issue
Punteggio 0
Isn't get my whyfi on my phone
Punteggio 0
My htc desire 820s dual sim wifi Mac address unavailable solution
Punteggio 0
Wifi ic jumper htc one e 9plus
Punteggio 0
Aggiungi la tua risposta
Jonathan Chianglin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 33,444
