Salta al contenuto principale
The eMac was an all-in-one G4-based Mac designed for the education market and released in April 2002. It was the last Mac to use a CRT display and was sold at a low price to schools and other institutions.
What can I do with a damaged eMac?
I took my US bought eMac and plugged it into a UK socket, and it blew. Is it worth fixing? Any idea how much that should cost? Thanks.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
4 Risposte
Soluzione Prescelta
kitbaker1, "Is it worth fixing?" Depends on what failed. Check the power supply. It is possible that the damage is minor, i.e. Fuse or capacitors. Could be an easy fix.
Punteggio 5
2 Commenti:
How can I change the fuse?
da
rrame which fuse?
da
Parti e strumenti correlati
You could always turn it into an aquarium ;-}
Here's how: Turn Your Old iMac into an Aquarium with the DIY Macquarium Kit Read more: Turn Your Old iMac into an Aquarium with The DIY Macquarium Kit
Punteggio 3
There is a lot of protection built in to help with your problem. What model emac is it? I agree, it could just be the power supply.
Punteggio 0
You can take in it and have the power supply board checked out or replaced. May not be worth the time and cost to repair it.
Ron
Punteggio 0
Aggiungi la tua risposta
kitbaker1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 600
