Salta al contenuto principale
Repair and disassembly guides for Acer Iconia Tab tablets.
20 Domande Visualizza tutte
How to fix shutdown of an acer iconia B1-730?
My acer iconia 7 B1-730 would not charge and turn on at all after randomly shutting down when its battery was at around 50%. Don't know why either the charger or the device itself, but still it won't turn on, is there anyway of fixing this?
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
1 Risposta
Risposta Più Utile
You can go through the easy steps first, try a different cord, try a different brick. Most likely though your issue lies with the battery or the board. You can order a battery online if you are confident enough to change it out yourself, but if it's a board issue you'd be better off getting a new tablet rather than spending the money to fix that one.
Punteggio 1
Aggiungi la tua risposta
Christian Balon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,846
