How can I make my computer faster?
My computer is running slower than it used to. How can I make it work better and faster?
Questa è una buona domanda?
There are many hardware and software ways to make your computer faster. Hardware fixes would be increasing the ram, upgrading the processor or the hard drive. Software fixes can include defragmenting the hard drive, cleaning out the hard drive of excess files and by fixing registry errors. Fixing the registry and deleting excess temporary files and such can be done using a program called CCleaner; which is a free program to download and will significantly help your computer run more efficiently. You computer has a built in defragmentation program which can be found by searching defragmentation, then run the program.
Parti e strumenti correlati
Well, I looked up some specs for the computer you have and I found you some RAM. The max amount of RAM your machine will take is 4GB, so if you get 4 of the 1GB chips you will max it out.(That's a good thing)
Your RAM will run at MAX power when you have you have an equal amount in the 4 slots.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 565
