Salta al contenuto principale
Model number NX785QC8G, released in 2014. RK3188 Quad core ARM Cortex A9/1.6GHz Processor, 1GB DDR RAM.
96 Domande Visualizza tutte
Why is my battery not holding a charge?
After a full charge, the device will only stay on for an hour or two.
Questa è una buona domanda?
Punteggio 11
1 Commento
my nextbook wont comeon at all
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
Be sure you are using the charger that was provided from the manufacturer. Generic chargers tend not to charge the device properly and may kill the battery cells.
If you are using the appropriate charger, and your nextbook is still not holding a charge, it is likely that your battery is dead and you will need to buy a replacement.
Punteggio 8
4 Commenti:
So what battery do we buy & where are the guides on how to do this ?
I have the same problem, I need a new battery.
da
please give me something to do
da
Charger will not charge battery give help on what to do
da
Well we have to use a 5 volt battery charger what we do then
da
Well we have to use a 5 volt batterywhat do we do then
Punteggio 2
How old is the battery?
Over time, rechargeable batteries lose their ability to hold a charge.
It might just be time to replace the battery.
Punteggio 1
Where done I get a battery.
Punteggio 1
Aggiungi la tua risposta
Zeke sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,744
