Salta al contenuto principale
A Toshiba brand laptop manufactured in 2008. Comes with DVD drive, 3 GB of RAM, a 15.4" screen, a 1.86GHz Intel Pentium Dual-Core T2390 processor, and weighs 5.7 pounds.
9 Domande Visualizza tutte
Update Ram to 8GB instead of 4
Can I update my Toshiba Satellite L305-S5875 Laptop to 8.00 GB of ram memory from 4.00 GB? Or will this cause my Laptop to crash?== Heading text ==
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
As per Toshiba specs:
"Operating System:
• Genuine Windows Vista® Home Premium (SP1, 32-bit version)
Memory:
• Configured with 3072MB PC5300 DDR2 SDRAM (both memory slots may be occupied). Maximum capacity 4096MB"
- Technically:
I am not sure modules of 4GB DDR2 laptop RAM exist. I believe they are a maximum of 2GB RAM per stick. But don't quote me on that. So probably unfeasible to upgrade beyond 4GB RAM.
- In theory, you should have 2GB+1GB RAM already installed; if you decide to upgrade to 4GB (2*2GB RAM, by replacing the 1GB stick), consider the following:
-- Your system is 32-bit Windows XP, unless you already upgraded it. You will need to upgrade to Windows 7 64-bit to take advantage of the 4th GB of RAM and see some difference;
-- Your system is an 8-year old Pentium with 1MB Cache. Expanding the RAM by 30% may not add much. The question here is, what do you expect to achieve by adding the extra RAM?
-- Your 8-year old HDD probably is at its last breathe. Consider replacing it instead. Ask a separate question on whether your system can handle an SSD (I am not sure of the answer) which I believe will be a sounder investment and probably add more zest to your computer.
Conclusion, in my opinion, it does not make sense to use more than 4GB RAM with a 7 years-old Pentium even if you could (technically, it does not seem feasible). Practically, I believe it will not amount to much improvement, better increase the RAM to 4GB by adding a 2GB stick, upgrading to Windows 7 64-bit, and investing instead in an SSD which will improve your system; and you can take that SSD with you to the next system or use it as external storage later on when your computer dies or you move on.
Punteggio 1
1 Commento:
Yes, 4gb sticks of ddr2-800 ram exist, but are pricey. A pair of 4gb sticks work fine in our L305-5955. Add an SSD and the combination works great with Win10 Pro 64bit.
da
Punteggio 0
Aggiungi la tua risposta
Angel Boekelman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,247
